Previous Topic: Access the ISO Disk Image
Sample log file
This log shows the connection, mounting, and start of the installation for the CA Job Management r3.1 for OpenVMS Alpha on a system running OpenVMS Alpha 7.3-2.
Steps 1 through 5 have already been performed.
$ ld connect LEVEL2:[KITS.CAJM31]CAJM31ALP.ISO
%LD-I-UNIT, Allocated device is $3$LDA6:
$ mount/over=id $3$LDA6:
%MOUNT-I-WRITELOCK, volume is write locked
%MOUNT-I-CDROM_ISO, CAJM31ALP: (1 of 1) , mounted on  _$3$LDA6: (ALPBOX)
$ run $3$LDA6:[000000]setup_alpha
UnZipSFX 5.20 of 30 April 1996, by Info-ZIP (Zip-Bugs@wkuvx1.wku.edu).
UnZipSFX is distributed by CA, Inc., and has been modified to spawn a subprocess
that installs either a product or a product patch kit. The original
distributors of UnZipSFX cannot and do not support CA's modified version.
Please see the Acknowledgements section of the CA OpenVMS product documentation
for more information.
  inflating: ca$setup.com
  inflating: installhelp.hlp
  inflating: cajm_product.key
  inflating: cajm$readme.txt
Setup location:$3$ LDA6:[000000]
           CA Job Management for OpenVMS
           Copyright (c) 1990,2011 CA.  All rights reserved.
                  PRODUCT
           1      Job Management Manager Install
           2      Job Management Agent Install
           I      CA NSM/CCS Integration Help
           P      Product Readme
           H      Install Help
           E      Exit
            Please Enter the Number of the Product you wish to
            install >>>>
