OpenVMS provides a mechanism to mount an ISO image of a CA OpenVMS product CD/DVD directly. These steps are valid for OpenVMS Alpha 7.3-2 and newer, and OpenVMS I64 8.2-1 and newer.
Notes:
To access the ISO disk Image
Search for the text “load_ldcld:”. The line immediately following the occurrence of this text should be “$ set command sys$input”. Starting with the line immediately after the line that reads "$ set command sys$input", cut all lines of text up to but not including the line that reads "$ RETURN 1" into a file named LD.CLD; this will be approximately 245 lines of text.
The first few and last few lines of the selected text should look as follows:
! Facility:
! Command Definition File for the LD Utility.
! Abstract:
! This file defines the following commands;
DEFINE SYNTAX PARAM_ALL
PARAMETER P1,LABEL=COMMAND,PROMPT="Command",
VALUE(REQUIRED,TYPE=LD_OPTIONS)
PARAMETER P2,LABEL=DEVICE,VALUE(TYPE=$DEVICE)
!<end-of-file>
$ if f$file_attributes("sys$system:ld$utility.exe","known")
Insert the following lines of DCL immediately before that line:
$ if f$file_attributes("sys$message:ld$msg.exe","known")
$ then
$ install replace sys$message:ld$msg.exe
$ else
$ install create sys$message:ld$msg.exe
$ endif
Close the file and terminate your editing session.
$ SET COMMAND LD
For OpenVMS Alpha 8.2 and up, execute the following:
$ SET COMMAND SYS$UPDATE:LD.CLD
The above commands should be executed whenever you login.
$ @SYS$STARTUP:LD$STARTUP.COM
$ LD CONNECT disk:[dir-path]filename.ISO
The system responds with the device name of the logical disk device that the .ISO file was connected to. You will need this device name for the following step.
$ MOUNT/MEDIA=CD/OVER=ID logical-disk-device-from-step-6
$ DISMOUNT LD-device-name
$ LD DISCONNECT LD-device-name
You can do this after you complete each installation and before repeating steps 6 and 7 for other ISO product disk images, or after you have completed all installations. If you do this after all installations, repeat these commands once for each ISO product disk image that was connected and mounted.
