This guide describes all Job Management Manager (the manager) DCL commands in alphabetical order. The commands are listed in the following two sections, based on what you enter at the DCL prompt:
Each command description includes the following:
Some commands are management commands, as noted. Use of a management command requires that the user have SYSPRV or OPER privilege, except where otherwise stated in the individual command description.
Note: You must use quotes to enclose commands that contain spaces, both at the DCL level and when at the SCHEDULE> or SCHEDULE CONFIG> prompt. At the DCL prompt, you must use quotes to enclose commands that contain the @ sign, but not at the SCHEDULE> or SCHEDULE CONFIG> prompt. Use quotes to enclose a case-sensitive_COMMAND for another operating system when using /MODE=REMOTE.
