Previous Topic: Overview
Next Topic: SCHEDULE>
Node-Related Command Options
The manager can manage jobs on different nodes. The following command options can be used in several Job Management commands:
Option
Description
/CLUSTER_NODE
Name of a Job Management Manager node in the local cluster that you want to restrict job execution to
/NODE
Same as /CLUSTER_NODE
/REMOTE_NODE
Name of the remote Job Management Agent (the agent) node where you want to run a job. This option is only valid when the MODE of the job is REMOTE.
/SERVER
Name of the Job Management Manager node outside of the local cluster where the database for the job resides
