Previous Topic: Examples
Next Topic: Format
DELETE
Removes the specified job from the Job Management Manager database, or removes the Special Day Class if /SD_CLASS is specified.
This is a management command when used to delete a Special Day Class.Description
You can delete a currently running job from the database without halting the job. To halt a job that is currently running, see the SCHEDULE ABORT command.
To delete a job, you must own it or have WRITE access to it. For more information on privileges, see the CA Job Management for OpenVMS Administration Guide.
