SCHEDULE> CREATE _VMS Command: @SYS$DEVICE:[DOE.PROJ-C]WKLY-COPY.COM _Job Name [None] : WKLY RENAME _Schedule Interval [None] : F W6 18:00:00 _Days [ALL]: (NONE,FRIDAY) _Start Time [ 9-AUG-1996 18:00:00.46] : _Output file [None] : SYS$DEVICE:[DOE.PROJ-C.WKLY]WKLY-RENAME.REP Comment [None] : Check for weekly ljt/copy to subdirectory and rename/check for renamed ljts. _%NSCHED-I-RQSTSUCCSS, Job 2043 - Created
The manager puts the output in a specified file named SYS$DEVICE:[DOE.PROJ-C.WKLY]WKLY-RENAME.REP.
SCHEDULE> CREATE/PROMPT _VMS Command: @SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY-COPY.COM _Job Name [None] : WEEKLY-RENAME _Group [None] : WEEKLY _Type [None] : PROJECT-COSTS _Stall Notify [None] : _Schedule Interval [None] : F W6 18:00:00 _Days [ALL]: (NONE,FRI) _Special Day Restrictions [NONE]: _Start Time [ 7-AUG-1996 18:00:00.04] : _Output file [None] : SYS$DEVICE:[EXAMPLE.PROJECT-C]WEEKLY- RENAME.REP _Mode (Detached, Batch, Remote [Detached] :) _Cluster Node [Default] : _Retain (Success, Error, None or All [ALL]:) ALL _Restart (Yes, No [Yes]:) YES _Retry (Yes, No [No]:) YES _Notify (Yes, No [Yes]:) NO _Send_Mail (All, Error, Success or None [NONE]:) ALL _Send MAIL on Special Day Action (Yes, No [No]:) _Use_next_time (Yes, No [No]:) YES _OPCOM (Yes, No [No] :) _Mail_Address [EXAMPLE] : EXAMPLE _User_Name [EXAMPLE] : EXAMPLE _Run Priority [Default] : _Pre Function [None] : DIR/PRINT[EXAMPLE.PROJECT-C]*.REP _Post Function [None] : DIR/PRINT[EXAMPLE.PROJECT-C.WEEKLY]*.REP _Maximum Time Warning [None] : _Maximum Time Job [None] : _Synchronization [None] : _Comment [None] : Check for weekly rep's/copy to subdirectory and rename/check new rep files %NSCHED-I-RQSTSUCCSS, Job 10521 - Created
As a result, the manager prompts the user for the following additional qualifiers:
/GROUP |
/PREFUNCTION |
/TYPE |
/POSTFUNCTION |
/CLUSTER_NODE |
/MAX_TIME |
/RESTART |
/SYNCHRONIZATION |
/RETRY |
/SD_RESTRICTION |
/NOTIFY |
/MODE |
/SEND_MAIL |
/RETAIN |
/MAIL_ADDRESS |
/OPCOM |
/USER_NAME |
/TJOB |
/RUN_PRIORITY |
/SJOB |
The user specifies the following for mail notification:
The user also specifies a prefunction and postfunction:
DIR/PRINT [DOE.PROJECT-C]*.LJT;*
DIR/PRINT [DOE.PROJECT-C.WEEKLY]*.LJT;*
