Possible Causes |
Possible Solutions |
Job has a node restriction |
Use SCHEDULE MODIFY JOB /NOCLUSTER_NODE |
Load balancing turned off |
Use SCHEDULE SET LOAD_BALANCE ON |
Weighting factors set to 0 |
Check logicals and see system manager |
Only one node has reasonable rating |
Check ratings using SCHEDULE SHOW STATUS |
Load Balance Group assigned to the job is empty |
Add one or more nodes to the Load Balance Group or remove the Load Balance Group from the job |
NSCHED$LBAL$WAIT_AVAIL_ |
Check the logical and see system manager. |
