Previous Topic: Job Successful But Shows Termination Status as Failure
Next Topic: Load Balancing Is Not Working
Job Management Manager Is Slow in Responding
Possible Causes
Possible Solutions
System resources fully used
N/A
nodename.LOG > 500 blocks
Use SCHEDULE SET DEBUG OFF or SCHEDULE STOP
History log > 2500 blocks
Use SCHEDULE CLOSE LOG [/SUMMARIZE]
Database fragmented; deletes > 200
Use SCHEDULE OPTIMIZE DATABASE to compress database
Many interface requests at the same time
N/A
Job Management Manager default transition
N/A
New scheduler joining cluster
N/A
NSCHED priority has been lowered
See system manager
NULL keys are not present in the jobs database
Shutdown JM Manager cluster wide and execute the DCL command $ CONVERT/FDL=NSCHED$DATA:VSS_STANDARD.FDL NSCHED$DATA:VSS.DAT NSCHED$DATA:VSS.DAT
