Previous Topic: The Callable Interface (SDK)
Next Topic: Dependent Jobs Relying on a Single Condition
System Management and Normal Maintenance
This section contains some hints from experienced Job Management Manager users.
System management is simplified with the manager. However, Job Management Manager detached processes behave differently from commands running under OpenVMS batch mode. Comparing Job Management Manager Detached Processes with OpenVMS Standard Batch Processes in the "An Overview of Job Management Manager" chapter gives a detailed comparison between the manager and OpenVMS Batch Processing.
Because privileged operators can modify or delete jobs, privileges can be used with caution. As an alternative, you can consider using EXECUTE identifiers, to allow efficient running without privileges.
You can create user-defined keys for frequently used Job Management Manager DCL commands.
At a minimum, operators must know how to do the following:
The following hints can help you perform normal maintenance:
