Previous Topic: Missing Information in the .ERR File
Next Topic: SYS$NODE Incorrectly Defined
Proxy Validation Error When Connecting to a Remote Node
If you can connect to a remote node, but a proxy validation error occurs, the name of the manager node may not be defined in the agent’s hosts database. When this is true, the agent cannot translate the Job Management Manager IP address into a name.
To define the manager node in the agent node’s UCX database, use the following command:
UCX> SET HOST UJM_Manager_node_name
/ADDRESS=UJM_Manager_node_ip_address
For a node running TCPWARE, you must edit TCPWARE:HOSTS.
For MULTINET, you must edit MULTINET:HOSTS.LOCAL.
