Agent errors can occur if the logical name sys$node is incorrectly defined. Check sys$node on the agent node to make sure the logical name:
If the DECnet nodename and the IP nodename differ, edit SYS$SYSTEM:NSCHED$AGENT_RUN.COM to define sys$node as a process logical name with the IP nodename for its value.
