Previous Topic: Privileges Needed to Use Job Management Manager
Next Topic: Wide Area Network Support
Privileges for Management Commands
To use management commands of the manager, you must have one of the following OpenVMS system privileges:
If you are unsure what your system privileges are, see your system manager.
Some management commands require other privileges. These privileges are described in the respective command descriptions.
For a description of general and management commands, see the chapter "Using the DCL Command Interface."
