The manager provides commands to create and control jobs, and management commands to control the operation of the manager system itself. In general, you need either SYSPRV or OPER OpenVMS privileges to issue the manager management commands (some management commands require other privileges as well). General users can perform operations on their own jobs, and on other jobs based on OpenVMS privileges and identifiers.
There are three types of access that users can have to jobs:
Your OpenVMS privileges and your UIC, the OpenVMS identifiers and UIC associated with the job, and identifiers that you hold, determine the access that you have to a job.
You have READ access to a job if at least one of the following is true:
You have WRITE access to a job if at least one of the following is true:
You have EXECUTE access to a job if at least one of the following is true:
To use the general commands of the manager on remote nodes of the network, you must have an authorized account on the remote node.
For a description of identifier-based access to jobs, see Identifier-Based Access to Jobs in the chapter "Getting Started with Job Management Manager."
