The following tables describe the uses of menus and buttons in the Job Display windows:
Menu |
Uses |
File (Linear Display window) |
Quit from Job Management Manager |
File (Graphical Display window) |
Quit from Job Management Manager Create a graphics file of the window contents |
Edit (Graphical Display window) |
Load jobs Clear window Open Load Balance Group Editor |
Edit (Linear Display window) |
Load jobs Clear window Open Load Balance Group Editor Sort jobs by job number, job name, or job owner |
Jobs |
Create a job Edit a job Delete a job Display job output Monitor a job |
Control |
Abort a job Put a job on hold Run a job Release a job that is being held |
Day Classes |
Create Special Day Classes Edit Special Day Classes Delete Special Day Classes |
Button |
Use |
Load Jobs… |
Displays the Load Jobs dialog box (see The Load Jobs Dialog Box section). After you fill in the selection fields and click on OK, the interface fetches the appropriate jobs from the database and adds them to any jobs already displayed in the Jobs windows. |
Clear |
Clears all jobs from the Jobs window and removes them from memory. |
Refresh |
Redraws the contents of the Graphical Display window. |
