Previous Topic: Summary of Job Management Manager Commands
Next Topic: Management Commands
General Commands
Command
Description
ABORT
Stops one or more running jobs.
COPY
Creates a new job, copying the settings for an existing job.
CREATE
Creates a new job or a Special Day Class.
DELETE
Deletes one or more jobs or a Special Day Class from the database. This is a management command when used to delete a Special Day Class.
HELP
Displays the Help screens for the DCL interface.
HOLD
Puts one or more jobs on hold.
MODIFY
Modifies one or more existing jobs or a Special Day Class.
RELEASE
Takes one or more jobs off hold.
RUN
Runs the specified jobs, regardless of conditions such as job dependencies.
SCRIPT JOB
Creates a command procedure capable of recreating the specified job or jobs.
SET JOB
Lets you change the number and frequency of attempts to run a job. You can also override or reset job dependencies for a job. Can be used with EXECUTE privilege. (Requires WRITE for DELETE).
SET RESTART_VALUE
Specifies at what point in a job to restart the job, if a system problem occurs. See also SET JOB /RESTART_VALUE in the CA Job Management
for
OpenVMS Command Reference Guide.
SHOW CPU_RATING
Displays the CPU (VUPS) rating of the system.
SHOW DEFAULT
Shows the default Job Management Manager node for a local or remote OpenVMS Cluster.
SHOW DELETES
Shows the number of jobs deleted from the job database since its last compression.
SHOW DEPENDENCIES
Creates a text file that represents a picture of a job’s dependency structure.
SHOW FISCAL_YEAR
Displays the fiscal calendar.
SHOW HISTORY
Displays information about the execution histories of jobs in a given log file.
SHOW JOBS
Displays information about the specified jobs.
SHOW JOBS/PROCESS
Displays process-related information for currently running local jobs.
SHOW JOBS/SYMBOLS
Creates a symbol for each job characteristic for the specified job.
SHOW LOAD_BALANCE
Shows whether the load-balancing feature for a local or remote OpenVMS Cluster is on or off.
SHOW LOGGING
Shows the current events being logged for a specific node, all nodes in an OpenVMS Cluster, or remote nodes of a network.
SHOW MAX_JOBS
Shows the maximum number of jobs that can run simultaneously for a specific node, all nodes in an OpenVMS Cluster, or remote nodes of a network.
SHOW NAMES
Displays all the group and/or type names that a user currently has assigned for jobs.
SHOW PRIORITY
Shows the default run-time priority setting for a specific node, all nodes in an OpenVMS Cluster, or remote nodes of a network.
SHOW SCHEDULED_RUNS
Predicts future execution schedules for jobs based on their historical run data.
SHOW SD_CLASSES
Displays the contents of requested classes.
SHOW STATUS
Shows information about the manager operating for a specific node, all nodes in an OpenVMS Cluster, or remote nodes of a network.
