Command |
Description |
CHECK |
Tells a scheduler to do a consistency check on a database and update its internal structures and counters to reflect the database and the current state of the system. |
CLOSE LOG_FILE |
Closes and renames the event-log file while the manager is running. |
CONFIG |
Creates, modifies, or deletes Load Balance Group definitions. |
DELETE |
Deletes one or more jobs or a Special Day Class from the database. This is a management command only when used to delete a Special Day Class. |
DELETE NSCHED$:RETRY.DAT; |
Deletes (stops) all remote node notifications currently being retried over the network. This command does not begin with SCHEDULE. |
OPTIMIZE DATABASE |
Reclaims unused space and optimizes the jobs database. |
RUN NSCHED$:DB_UTILITY.EXE |
Repairs the jobs database. This command does not begin with SCHEDULE. |
RUN NSCHED$:VSS_REPORTS.EXE |
Invokes the event-log report utility to select event-log report criteria and display or print a report. This command does not begin with SCHEDULE. |
SET DEBUG |
Sets debug logging for the manager. |
SET DEFAULT |
Sets the default manager node for a cluster. |
SET FISCAL_YEAR |
Defines a fiscal calendar to be used by the manager. |
SET LOAD_BALANCE |
Turns the load-balancing feature on or off in an OpenVMS Cluster. |
SET LOGGING |
Controls the event classes written to the Job Management Manager event-log file. |
SET MAX_JOBS |
Sets the limit for the maximum number of jobs that can be run simultaneously. |
SET NETWORK EXPIRATION_RETRY |
Sets the maximum time that a job-dependency notification on a remote node can be retried over the network. |
SET NETWORK INTERVAL_ENTRY |
Sets the interval for retry of notification of job completion on remote nodes during communication failures on a wide area network. |
SET PRIORITY |
Sets default run-time priority for jobs. |
SHOW NETWORK |
Shows the retry interval, retry expiration time, retry alias, and information about retry operations in progress on the local OpenVMS Cluster. |
STOP |
Stops the manager on one or more nodes. |
TYPE NSCHED$:RETRY.LOG |
Shows a history of every notification retry event attempted by a remote node. This command does not begin with SCHEDULE. |
