The following command erases the data in the online VPE trace file and starts writing at the beginning of the file. Use it when the VPE trace file fills up (an ASRB abend occurs). In batch, if the trace file fills up, you can rerun the job with a larger trace file.
@I$TRACE RESET
You must use the following procedure with this command.
CEMT S TDQ(ADRT) CLOSE
CEMT S TDQ(ADRT) OPEN
The following command produces internal diagnostics for a COMPILE of a CA Ideal program, a CATALOG of a CA Ideal dataview, or a RUN of a CA Ideal program. It also specifies which CA Ideal internal tasks or functions are logged. The command lets you log DIAL trace entries either to the VPE trace file or to a separate DIAL‑only trace file. The previous section described how to extract entries from the VPE trace file. The next section describes how to print trace information.
{'codes' }
SET [COMPILE] @I$DIALMASK {'ALL' }
[RUN ] {'ONLYcodes'}
{'ONLYALL' }
Source Transport can also process this command, but do not specify COMPILE or RUN.
Produces internal diagnostics for a COMPILE or CATALOG.
Since an online compile is normally an asynchronous task and online asynchronous tasks cannot be traced, you should produce the DIAL trace diagnostics for a compile in batch. If a batch compile is impossible, use one of the following methods to trace the compilation:
Remember that both of these methods can affect system performance for the duration of the trace.
Produces internal diagnostics for a RUN. You can also trace the CREATE MODULE and GENERATE PLAN or PACKAGE using the RUN option.
The DIAL trace codes for the CA Ideal tasks or functions to log. Entries are logged with the VPE trace entries to the ADRTRC file. Commonly used codes are listed on the next page. You can find a complete list in the “DIAL Trace Codes” appendix.
You can concatenate any combination of codes. For example:
SET RUN @I$DIALMASK 'RSTV'
SET COMPILE @I$DIALMASK 'BLF'
Before using this command with this option, you must activate a VPE service trace (@I$TRACE ON). See the section titled @I$TRACE-Executing a VPE Service Trace in the “CA Ideal Trace Facility” chapter.
Logs all codes. For example:
SET RUN @I$DIALMASK 'ALL'
The DIAL trace codes for the CA Ideal tasks or functions to log. In batch, these entries are always logged, without VPE trace entries, to SYSDIAL in z/OS or SYSLST in VSE. Commonly used codes are listed on the next page. You can find a complete list in the “DIAL Trace Codes” appendix.
SET RUN @I$DIALMASK 'ONLYRSP'
Logs all codes. In batch, these entries are always logged without VPE trace entries to SYSDIAL in z/OS or SYSLST in VSE. For example:
SET RUN @I$DIALMASK 'ONLYALL'
Online, ONLY has no effect. DIAL trace entries are always logged to the VPE trace file, which must first be opened with an @I$TRACE ON command.
To trace Source Transport Utility execution, use the following command syntax, omitting both the RUN and COMPILE options:
SET @I$DIALMASK 'ONLYcodes'
or
SET @I$DIALMASK 'ONLYALL'
