In a batch environment, the @I$TRACE ON command writes VPE trace records and, if requested, DIAL trace records to the VPE trace file with the following DD/DLBL name:
ADRTRC
Under z/OS, the @I$TRACE PRINT command reads the ADRTRC file and routes the output to the file with the DD or FILEDEF name:
AUXPRINT
You can then print or display this output using a standard operating system spooling queue or printing facility.
Under VSE, the @I$TRACE PRINT command reads the ADRTRC file and routes the output to the system printer; that is, to the device address specified in the first available PSSPRTnn entry in the IDSYSFT.
