Previous Topic: DEQUEUE CommandNext Topic: Using DEQUEUE
@I$UTIL PSS Online Dequeue
The following command dequeues a print file, the display status member, or the PSS directory if the resource is caught in an enqueue due to a system failure, a CA Ideal/CA IPC failure, or another failure level.
                    [print-number]
@I$UTIL OUT DEQUEUE [STATUS      ]
                    [DIRECT      ]
print‑number
Identifies a print file.
STATUS
Displays the status member.
DIRECT
Displays the output directory.
Important! Before using this command, be certain that the resource is locked due to an error condition and not due to a legitimate enqueue.
