Previous Topic: Internal Error FacilityNext Topic: Display VLS Library Index
@I$INTERNAL STATUS
The following command displays the release levels of the major CA Ideal, CA IPC, and CA Datacom components and the maintenance applied to this CA Ideal release.
@I$INTERNAL STATUS
The first part of the display shows release levels for CA Ideal, VPE, PMS, SCF, PSS, and CA Datacom/DB. The second part of the display shows the current maintenance level for CA Ideal.
Run this command, online or in batch, before and after applying each maintenance tape and before contacting CA Ideal Technical Support with a problem. CA Ideal Release Levels and Maintenance Level are also shown on the CA Ideal Trace Facility printout, as part of the environment page.
Example
Output (Mixed Environment)
When this command is issued in a mixed (CA Datacom/DB and DB2) environment, the following output results:
IDEAL 14.0 RELEASE LEVELS IDEAL OPTIONS VPE VERSION: 14.0 SCF VERSION: 11.0 PMS VERSION: 14.0 PSS VERSION: 11.0 DB: Y D-D VERSION: 14.0 D-B VERSION: 11.0 DBSQL: DATACOM DB2: Y DB2/CICS ATTACH: I710 VSAM: Y CICS APPLID: A11IC9P3 DB2 SUBSYS : D71C Maintenance:
The section on CA Ideal options indicates the following:
