Previous Topic: Working in the Installation Dialog EditorNext Topic: Add a Graphic File to the Installation Dialog
Specify the Input Order for the Fields
You can specify the order in which the input fields of an installation dialog should be processed during the installation of the PIF package.
To specify the input order for the fields
  1. Select the Input order check box in the installation dialog editor’s toolbox.
    Blue boxes appear for the input fields in the dialog creation area.
  2. Click the input fields (blue boxes) one-by-one to specify the input sequence.
    When this installation dialog is called during a later installation of the PIF package, the input fields in this dialog are processed in the specified order.
