Previous Topic: Check ulinks.sxp (Links)Next Topic: Check links.sxp (Links)
Check gac.sxp
In this step, the Installer checks the gac.sxp file (GAC = Global Assembly Cache), which contains sections that specify assemblies to remove.
The Installer removes an assembly specified in the #DeleteAssemblyn# section of the gac.sxp from the GAC, provided the last reference will be deleted. Otherwise only the reference to the current product is deleted.
