To obtain detailed diagnostic information on software installation jobs, you can view the output of the installation jobs on the target computers.
To view the results of installation jobs
The All Software Jobs node displays a list of all scheduled and completed job containers on this domain.
The list of target computers to which the job container was sent is displayed in the right pane.
The jobs for that target computer are displayed in the right pane.
The Job Container Target Job Properties dialog opens, displaying tabs with details about the selected job:
Provides status and error information in the Status Message field, if the installation job has failed. If errors occurred when the job was executed, the according error messages are displayed here (for example, SXP000290 - Product cannot be used for this system).
Click the Status Help button to search for more details about reason and solution for an error message, for example, SXP000290.
Displays trace information provided by the Data Transport Service (DTS) component.
Displays output provided by the Software Management Installer on the target computer. If the trace feature was turned on when the job was executed, the Job output tab provides trace information. If the trace feature was turned off when the job was executed, the output tab has fewer details, and, for jobs with no errors, it may be empty.
