Using the Packager for Windows › Package Programs that Write Hardware Configuration Data
Some programs write hardware configuration data into the application's binary files. Generally, this information cannot be modified on the target computer.
If you are packaging a program that writes hardware configuration data, do one of the following:
- Package the program on a reference system that has the same hardware configuration as the target computer.
- Use the manual method of packaging, in which the original setup is executed on the target computer.
