Previous Topic: Select the Packaging MethodNext Topic: System State Backup
Configure and Update the Reference System
When you use the automatic method, the Packager records all system changes resulting from the installation of the product. Therefore, the configuration of the reference system is important.
If you are creating the first product on the Packaging Computer and click OK on the Create Product Version dialog, the Packager automatically updates the reference system and displays the Updating Reference System message. This process can take several minutes, depending on the processing speed and the number of files on the computer.
To view the current reference system configuration and make any necessary changes, click the Configure Reference System button to open the Configure Reference System dialog.
