Using the Installer for Windows › How the Installer Installs Products › Check info.sxp (Product)
In this step, the Installer checks the info.sxp file and performs the following actions:
- Check whether the product can be used on the system.
- Check for dependencies on other products (internal and external).
- Remove the SxpRootDirn parameter (root directory n) from the file for later use and sets it to the correct value
- Establish the reset level. If a reset level was specified in the info.sxp file, for a specific product being installed, the Installer uses it. Otherwise, the Installer uses the reset level set in the Program section of the sxpengxx.ini file.
Note: If the installation fails, the changes that can be canceled depend on the value of the reset level.
