Previous Topic: Check original.sxp (Original Setup)Next Topic: Check uininnnn.sxp
Check ascnnnn.sxp (ASCII Files)
In this step, the Installer checks the #ScriptFiles# section in the ascnnnn.sxp file for uninstall scripts (ascnnnn.dei) that modify ASCII files. If any are found, the Installer executes each script found for each SXP archive file in the installation job being executed. By default, all changes are appended at the end of the ASCII file.
However, if an uninstall script specifies lines to be removed, the Installer does not remove those lines if they are also used by another product installed on the target computer.
