The manual method creates empty files that must be populated after the initial packaging process has completed. You can complete these files using the Packager's editor. To start the editor, right-click the archive file and select Edit Archive Files.
All SXP archive files can also be created manually after the packaging process has completed, using the main Product Archive window.
