Previous Topic: Reference Counter-Dependent UninstallationNext Topic: Product Archive on a Network Share
Product Archive Configuration
The Packager for Windows manages products in a product archive. The product archive is organized hierarchically and is mapped to a directory tree. You can configure the root of this tree by selecting File, Open Product Archive.
On the appearing Open Product Archive dialog, you can enter the directory name of the new product archive you want to create, or you can enter the name of an existing product archive that you want to modify.
The default directory for the product archive of the reference system is called SxpArchive and is located on the drive where the Packager directory is installed, as follows
Drive_of_Packager_directory\SxpArchive
Important! Do not create the product archive under the Packager directory, because it will be deleted, if the Packager is uninstalled.
