Previous Topic: Reference System UpdateNext Topic: Version-Dependent Installation
File Options
During a reference installation, two installation or removal options apply to the recorded files:
You can assign one or both of these options to each individual file. Use the Product Files Filter tab on the Configure Reference System dialog to assign these options to groups of files that have the same path name and file extension.
On the Configure Reference System dialog the options are represented by the following icons:
Icon for the file option Version dependent installation
Indicates version-dependent installation of the files
Icon for the file option Reference counter dependent uninstallation
Indicates reference counter-dependent uninstallation of the files
Icon for the file option Version dependent installation Icon for the file option Reference counter dependent uninstallation
Indicates that both options apply to the files
