Previous Topic: Reference System SettingsNext Topic: Keys to Scan
Paths to Scan
Specify the paths that you want to be scanned on the Paths to scan tab of the Configure Reference System dialog.
If you do not specify a path on the Paths to scan tab, changes made to the path during the reference installation are not recorded, and the path is not reset to its original state after the reference installation has completed.
During a reference installation, the Packager records the following items:
You can specify either an entire drive or a specific path. If you specify a path, only that path is checked. For example, if you specify c:, the entire c: drive is checked. If you specify c:\win, the c:\win directory and all of its subdirectories are checked.
To add another directory to the path list, use the Browse button, or enter the directory name directly in the Path field. Removing a folder from the path list does not affect the Paths to exclude tab.
To add or remove special folders from the paths list, use the Special Folder dialog. Removing a special folder from the path list automatically adds it to the list of available folders. Adding a special folder to the path list removes the folder from the list of available folders.
In general, additional and modified files and directories are copied completely to the product. The exception is ASCII files. For each ASCII file, you can specify that only the changes to the file are recorded. By default, changes to any file with the .ini extension are always recorded in this way.
For deleted files and directories, the Packager records that the marked files or directories are to be deleted on the target computer when the product is installed.
If existing files or directories are deleted or modified on the Packaging Computer's reference system while the product is being installed, they can be restored only if the following requirements are met:
