Previous Topic: Keys to ExcludeNext Topic: Expandable Registry Values
Paths to Exclude
Use the Paths to exclude tab to specify drives and paths that are not checked for changes during a reference installation.
If you specify a path on the Paths to exclude tab, changes made to the path during the reference installation are not recorded. However, the path is reset to its original state after the reference installation has completed.
Gray folder symbols indicate defaults that cannot be changed. Yellow folder symbols contain either defaults or values you have set that can be changed, if needed.
In the Path field, you enter the name of the path to be excluded.
If you select the Recursively option, all subdirectories of all paths you specify are excluded.
In the File mask field, you enter the name of a file or a file group to be excluded.
The following table includes examples of file masks:
Path
File Mask
C:\
cmos.ram
C:\
pagefile.sys
C:\
boot.ini
C:\tmp
trace.*
C:\test
Note: Some of the above examples are default entries set by the Packager; they cannot be modified.
