Remote Control Viewer › Viewer Pane › My Sessions Folder › Disconnect a Session
You can disconnect an active remote control session.
To disconnect from a session currently in progress
- From the DSM Remote Control tree view, expand the Sessions folder.
- Right-click the computer to which you are connected and select one of the following options: Disconnect, Normal; Disconnect, Lock Desktop; Disconnect, Log Off; or Disconnect, Reboot.
The Disconnect confirmation dialog appears.
- Click Yes.
The computer is disconnected.
