Remote Control Viewer › Viewer Pane › Address Books › Find a Computer
Find a Computer
You can easily locate computers in address books.
To search an address book for a computer
- Right-click either the Global Address Book or the Local Address Book node and click Search.
The Search dialog appears.
- Enter the name of the computer you want to find.
- (Optional) Select the Search Child Address Books option if you want to search in child address books.
- (Optional) Select the Match Folder Names option if you want to match folder names.
- Click Find.
The search results appear in the list view at the bottom of the dialog.
More information:
Global Address Book
Local Address Book
