Previous Topic: Contact CA TechnologiesNext Topic: Replayer Pane
Remote Control Replayer
Welcome to the Remote Control replayer component. The replayer is available from the Remote Control viewer, and it lets you play back previously recorded host sessions.
It can also be launched from the Windows Explorer by double-clicking a replayer *.urc file or by using the gui_rcLaunch command.
Note: You can also launch a web version of the replayer, the RC Web Replayer interface, by double-clicking RCReplay.html located in the Program Files\CA\DSM\bin folder.
