Previous Topic: Delete Users
Uninstall Remote Control
To uninstall Remote Control, use the Windows Control Panel, Add/Remove Programs applet. The Add/Remove Programs applet contains buttons for removing an application (Remove) and modifying an application (Change).
To remove your Remote Control agent
  1. Select CA ITCM Agent + Remote Control plugin.
    A maintenance-type dialog opens.
  2. Click Remove and follow the wizard instructions.
    Remote Control is uninstalled.
