The User Properties dialog is invoked by selecting a user in the Users tab and clicking Properties. Use this dialog to view and modify properties for individual users. You may make changes to the Full Name and Notes field, and change the user password.
This dialog contains the following fields:
Displays the name of the user. This field cannot be modified; therefore, it is disabled.
Defines the full name of the user.
Displays comments about the user and lets you modify them.
Specifies the new password for the selected user.
Requires you to reenter the new user password as confirmation that it has been entered correctly.
This dialog contains the following buttons:
Invokes the Change User Password dialog, letting you update the user's password information.
Updates the user properties that have been modified.
