You can automatically purge rejected sessions In the Rejected Sessions pane using the Age of rejected sessions to purge policy. This policy enables you to configure a separate purging value for rejected sessions as compared to the value used for purging closed sessions, thereby customizing session retention to match your corporate policy.
To purge rejected remote control sessions
The remote control manager policies are displayed in the right pane.
The Setting Properties dialog appears.
This purge action occurs during a scheduled session purge, and the Next session purge policy controls the regularity of the session purges.
Note: The Value field in this dialog is enabled only if you unseal the policy first.
The Setting Properties dialog appears again.
The changes are saved.
Note: Changing these values does not require restarting the management server.
Note: For more information about the remote control configuration policies, see the Configuration Policy section of the DSM Explorer Help.
