Use the Users tab to add and delete users and view their properties. Changes are applied immediately.
To add a new user
Permits you to create a user name and password for any user you want to add.
Permits you to select a user from a list of local and domain users previously established by the administrator of the local network.
Remote Control displays the dialog applicable to the type of security provider you selected:
Displays the Create New User dialog. Go to Step 4 to continue.
Displays the Add Users dialog with a listing of domains. Go to Step 7 to continue.
The user description appears in the list view of the Users tab. Go to Step 10 to continue.
Note: Each time you expand the DSM Explorer tree, a message appears requesting you to wait for the user information. The listing is produced almost immediately.
The Add button is enabled.
The user or group of users you selected appears in the Users to be added list.
The Users tab appears with your selection in the list.
The user or group of users is added, and the user information remains in the Users tab until the user is deleted.
