Previous Topic: Importing and Exporting Local Address BooksNext Topic: rcUtilCmd Command—Import an Exported Address Book into the Local Address Book
rcUtilCmd—Export a Local Address Book
The export command lets you export a local address book.
The command has the following syntax:
export [exportedbook]
exportedbook
Specifies the name of the file to be exported. This file is the local address book of the currently logged on user. The default is exportedbook.
The rcUtilCmd.exe program creates the default file, rcExportedLAB.xml, in the current working directory.
