Symptom:
When I am using an OS image, for example, a Vista image, I noticed that the OS parameter TimeZone is truncating values.
Solution:
This happens if the Timezone parameter contains blank values.
For a Vista image, change the setting of the TimeZone parameter to "\"W. Europe Standard Time\"" or "\"W. Europe Standard Time\" UK time"
Example: Modify OSIM install parameter TimeZone
This example shows how to change the parameter TimeZone for a Vista image.
cadsmcmd targetcomputer action=modifyInstallParameter
name=computer name paramname=TimeZone paramvalue="\"W. Europe Standard Time\""
Note: If the parameter is a map list or extended map list, use the format "<key> <comment>". The key and the comment are separated by a blank, and the comment is optional. And if the key contains blanks, enclose it in quotes.
