The following table lists all events generated by the domain manager (OSIM part) for operating system installation jobs, targets, and boot server.
Event ID |
Event Meaning |
2000 |
OSIM Manager started |
2001 |
OSIM Manager stopped |
2002 |
New boot server xxx |
2003 |
New target computer with MAC address xxx reported by boot server yyy |
2004 |
Target computer xxx attached to boot server yyy |
2005 |
Target computer xxx detached from boot server yyy |
2006 |
Image xxx attached to boot server yyy |
2007 |
Image xxx detached from boot server yyy |
2010 |
OSIM job xxx activated |
2011 |
OSIM job xxx sent to boot server yyy |
2012 |
OSIM job xxx cancel request sent to boot server yyy |
2013 |
OSIM job xxx cancelled |
2014 |
OSIM job xxx terminated with status yyy |
2015 |
OSIM job xxx succeeded |
2016 |
OSIM job xxx pending |
2017 |
OSIM job xxx installing |
2019 |
OSIM job xxx terminated with error yyy |
2021 |
OSIM job xxx terminated with error: the boot configuration is not linked to a target computer |
2022 |
OSIM job xxx terminated with error: the boot configuration is linked to more than one target computer. |
2023 |
OSIM job xxx terminated with error: no activation time found |
2024 |
OSIM job xxx terminated with error: the boot configuration is not linked to any OS image. |
2025 |
OSIM job xxx terminated with error: the boot configuration is linked to more than one OS image |
2026 |
OSIM job xxx terminated with error: the OS image yyy has no parameter values |
2027 |
OSIM job xxx terminated with error: the value for parameter yyy was not found in the database |
2028 |
OSIM job xxx terminated with error: the target computer is not assigned to any boot server |
2029 |
OSIM job xxx terminated with error: the target computer is assigned to more than one boot server |
2030 |
OSIM job xxx terminated with error: the boot server yyy has no host object |
2031 |
OSIM job xxx terminated with error: communications problem: error sending message to boot server |
2032 |
OSIM job xxx terminated with error: job timeout, no reply from boot server. |
2033 |
OSIM job xxx terminated with error: the boot server did not accept the installation or job cancellation order |
2034 |
OSIM job xxx terminated with error: the required OS image is not available on boot server yyy |
2035 |
OSIM job xxx terminated with error: the required boot disk image yyy is not available on the boot server |
2036 |
OSIM job xxx terminated with error: the job was forcibly aborted on user request. The installation was already started, the state of target system is unknown |
2037 |
OSIM job xxx terminated with error: the 'InstallCounter' parameter is missing. |
2038 |
OSIM job xxx terminated with error: the installation was aborted by the target computer. The previous installation is probably intact. |
