Symptom:
Cannot install an OS image from a network share when it uses DOS boot images containing a MS client.
Solution:
The OSIM target uses a boot image including a MS Client to install the OS image from a network share. On some platforms you cannot run the MS Client or the setup of the OS image has not enough free RAM when the MS Client is loaded.
In such cases, we recommend to use WinPe or - if this is not possible (Linux) - to switch the responsible boot server to TFTP download method.
Then, the boot image will not load the MS client, but will use the small tftp.exe program for download.
