Symptom:
When I create OS images with the Image Prepare System the administrator password is set to default. This does not seem to be secure.
Solution:
OS images created with the Image Prepare System use templates and default values for all required install parameters. The administrator Password parameter is set to default.
We recommend changing the default value of the Password parameter of the OS images. After registering the OS image, use the DSM Explorer to change the default value of the Password.
