Using the Image Prepare System › Using GHOST (DOS) Imaging Tools › Build the GHOST (DOS)-based OS Image
To build a GHOST-based OS image, launch the command prompt using the Start button and enter the following command at the DOS prompt:
createOSImage -i Win2K -o GHOST-W2K -s c:\win2k -k productkey
When the command successfully completes, the image is stored at the MANAGEDPC\IMAGES directory relative to the installation directory of CA\DSM:
- The files Win2k.par, Win2k.inf, and Win2k.bat are stored at MANAGEDPC\CAMENU.
- The OS image provides a default installation of Windows 2000, Windows XP, or Windows 2003 according to the prototype installation, and includes a default set of parameters that can be set from the OS Installation Manager.
- The OS image provided will work with the default boot images, osinstal.2 and osinstal.3; no special boot images are needed.
