The setup of the scalability server provides a boot server property sheet where the user can enable share access. Shares are not created if share access is disabled.
The boot server setup installs a switch tool, “sdbsswitch,” that can be used to change the boot server access method later.
The sdbsswitch tool creates or removes the OSIM shares and adjusts the OS images in the image store according to the access method:
Note: All OSIM images (except Ghost and ImageX images) are prepared to work with both share and tftp access.
Note: OSIM LINUX images always use NFS shares. The NFS share must contain the LINUX CD image. For more information, see "Installing LINUX from a Central NFS Server". The sdbsswitch command does not remove or create NFS shares.
sdbsswitch -s will create the directory tree and remove <image>.caz.
