Previous Topic: Power Management CalendarNext Topic: Configure the Shutdown Behavior Policy
Non-Conflicting Time Ranges
Make sure that you define only non-conflicting time ranges in the power management calendar configuration policy. The non-conflicting time ranges help you create a power management calendar where you can determine the result of each time range without any ambiguity.
The following example scenarios let you understand the various types of conflicting time ranges:
More information:
Define a Time Range
Power Management Calendar Policy Group
