To specify throttling for NOS-less software package transfers in software delivery, configure the SD-specific throttling configuration policy in the DSM Explorer. After you configure the policy, apply the policy to the software delivery agent.
Any other software delivery agent reporting to the same scalability server can specify a different value for throttling. For example, you can specify one throttling value for NOS-less software package transfers on one software delivery agent and a different value on the other software delivery agent reporting to the same scalability server.
To configure throttling for NOS-less software package transfers
A list of the configuration policies appears.
Specifies the bandwidth limitation of each internal NOS-less software package download. If the value is set to Default, internal NOS-less downloads for software packages between a scalability server and an agent follow the default throttling value of the File Transfer Server plug-in. If a value other than Default is used, internal NOS-less downloads for software packages override the default throttling value and use the configured value. Valid values are Default, Unlimited, 4 Mb, 2 Mb, 1 Mb, 512 Kb, 256 Kb, 128 Kb, 64 Kb, and 32 Kb.
Default: Default
The Internal NOS-less download: Throttling configuration policy parameter is configured.
