Software delivery lets you enable or disable encryption for NOS-less software package transfers, for example, you can disable encryption for the software packages that are sent between a scalability server and an agent. The ability to configure encryption helps you deal with situations where the network performance becomes an issue because of the encrypted NOS-less software package transfers. In such cases, you can disable encryption for NOS-less software package transfers and let the network hardware cache the data. So, you use the network hardware to cache the data being transferred over the network without compromising on the network performance.
