Previous Topic: Moving the OSIM Job InformationNext Topic: Diagnosing an Error during a Computer Move Operation
Configure the OSIM Move Configuration Policies
To move the OSIM job information during a computer move operation, configure the OSIM move configuration policies. Using these policies, you can control the overall behavior of transferring the OSIM job information from a previous domain manager to a current domain manager. You must apply these policies on the domain manager to which the agents are being moved. The values of these policies on the previous domain manager do not influence the behavior of moving the OSIM job information to the current domain manager. Thus, the OSIM move policies applied on the current domain manager define the transfer behavior of the OSIM job information, and not the policies applied on the previous domain manager.
To configure the OSIM move configuration policies
  1. Navigate to Control Panel, Configuration, Configuration Policy, policy name, DSM, Software Delivery, Manager.
    A list of configuration policies appears.
  2. Double-click the following policies, and specify appropriate values in the Setting Properties dialog:
    Computer move: OSIM Move enabled
    Specifies whether to move the OSIM job information along with the installation records from a previous domain manager during an SD computer move operation. You can set the parameter value to True or False. Setting the parameter value to True always attempts to move the OSIM job information and the installation records from the previous domain manager. However, setting the value to False disables transfer of the OSIM job information, and attempts to move only the installation records.
    Default: True
    Computer move: OSIM Move Postpone codes
    Specifies whether to move the installation records from a previous domain manager after initiating transfer of the OSIM job information. If transfer of the OSIM job information fails with an error code that is present in the error codes list specified for this setting, the transfer of the OSIM job information and the installation records is postponed until the next computer move attempt is made. However, if the transfer of the OSIM job information succeeds or fails with an error code not included in the list specified for this setting, the process of moving the installation records is initiated.
    Note: The error codes list is a comma-separated list and can include the following error codes:
    1,2,3,4,5,6,8,9,12,13,45,107,207,211,214.
    Default: 1,2,3,4,5,6,8,12,13,45,211
  3. Click OK.
    The OSIM move configuration policies are configured.
More information:
Error Codes
